[Mapguide-trac] [mapguide-trac] #2139: Remember selected layer in Layer setup (map definition)
trac_mapguide at osgeo.org
Tue Oct 9 04:12:00 PDT 2012
Reporter: bigs | Owner: jng
Type: enhancement | Status: new
Priority: low | Milestone: Maestro-4.0-maintenance
Component: Maestro | Version: 2.1.0
Severity: trivial | Keywords:
External_id: |
It would be helpful if Maestro would remember what layer is selected when
switching between "Layers by Group" / "Layers by Drawing Order" and "Base
Layer Groups".
For example, if you choose a layer from the "Layers by Drawing Order" list
and switch over to "Layers by Group", it would be nice if the layer is
still selected, and if it's in a folder the folder should be expanded,
displaying the selected layer.
This feature is part of Mapguide Autodesk Studio and it is very helpful
when the map contains many folders and layers.
Regards,
Birgir G.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2139>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
