[Mapguide-trac] [mapguide-trac] #2141: Support base layers in RenderDynamicOverlay
trac_mapguide at osgeo.org
Wed Oct 10 04:07:55 PDT 2012
Reporter: jng | Owner:
Type: enhancement | Status: new
Priority: low | Milestone: 2.5
Component: Rendering Service | Version:
Severity: trivial | Keywords:
External_id: |
Currently if we want to render an image of a map with any tiled base
layers at any arbitrary scale, we have to use the RenderMap API.
The problem with the RenderMap API, is that the background color is pre-
filled into the image making it fully opaque and un-suitable for
overlaying on top of another image.
The problem with the RenderDynamicOverlay API (which is normally the API
we would use in this case) is that tiled base layers are omitted during
rendering.
Attached is a patch that introduced a new behavior flag (RenderBaseLayers)
for the RenderDynamicOverlay API, and a modification to
RenderDynamicOverlay to include such tiled base layers if the new
RenderBaseLayers is OR'ed into the behavior parameter.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2141>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
