[Mapguide-trac] [mapguide-trac] #2142: Extent in layer preview is calculated wrongly (OGR provider)
trac_mapguide at osgeo.org
Wed Oct 10 05:16:16 PDT 2012
Reporter: nkjoller | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-5.0
Component: Maestro | Version: 2.2.0
Severity: minor | Keywords:
External_id: |
Comment(by jng):
The problem is simple.
The all so powerful CS-Map library that supports thousands of different
coordinate systems and transformations and used by MapGuide, is not
available for Maestro to use over the mapagent http interface, because no
coordinate transformation APIs are exposed over it.
So as a result, we resort to using the imperfect Proj.Net library which
does not have the same power, reach and flexibility as CS-Map. The numbers
you see generated are the result of going through this library.
There are solutions for this problem in the long-term (I'd have to
implement them first). The short term one would be to write a web-based
helper script in PHP/ASP.net/Java that can access the MgCoordinateSystem
API and do this extent number crunching for you
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2142#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
