[Mapguide-trac] [mapguide-trac] #2142: Extent in layer preview is calculated wrongly (OGR provider)
trac_mapguide at osgeo.org
Wed Oct 10 07:07:56 PDT 2012
Reporter: nkjoller | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-5.0
Component: Maestro | Version:
Severity: minor | Keywords:
External_id: |
Changes (by jng):
* version: 2.2.0 =>
Comment:
The problem with consuming data via the OGR FDO provider is that FDO is
not working against a particular data store or RDBMS whose capabilities we
know of and are well documented, but against another generic data access
API (OGR) whose capabilities may not be enough for us or may be ambiguous.
As a result some things may not exactly translate 1:1 if consuming data
through the OGR FDO provider. I normally suggest using the OGR provider as
a "last resort" when using a specialized provider or moving data to a data
store that is supported by a specialized provider is not an option.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2142#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
