[Mapguide-trac] [mapguide-trac] #2147: Double click item in Validation result to open
trac_mapguide at osgeo.org
Mon Oct 15 00:14:08 PDT 2012
Reporter: hm | Owner: jng
Type: enhancement | Status: new
Priority: low | Milestone: Maestro-4.0-maintenance
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
When validating a map or anything else, and you get some errors. It would
be nice to be able to just double click the row to jump to the specified
resource. The Validation result window is not modal and when you double
click a row, the Validation Results window should be put to the background
(not closed) and the resource should be displayed in the main Maestro
window.
If I validate a map today and have an error on one of the feature sources
I have to either browse the Site Explorer to find it or go trough the
layers of the map and when finding the layer go to the feature source.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2147>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
