[Mapguide-trac] [mapguide-trac] #2151: Address Local/LocalNative connection quirks
trac_mapguide at osgeo.org
Tue Oct 16 07:17:12 PDT 2012
Reporter: jng | Owner: jng
Type: task | Status: new
Priority: low | Milestone: Maestro-5.0
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
The Maestro.Local and Maestro.LocalNative connections by design will not
actually respect the ini path parameter for subsequent connections made
for that provider in the same application session.
The reason for this is that both providers call MgdPlatform.Initialize and
MapGuideApi.MgInitializeWebTier respectively, that load the necessary
libraries (FDO) as indicated in the ini file. Subsequent calls to such
methods return immediately, as the necessary libraries have already been
loaded.
Because there is currently no API in MapGuide or mg-desktop to actually
tear down this initialized state (once set), creating subsequent
connections for that provider may not (probably will not) respect the
connection parameter values passed in.
Basically connections to the Local or LocalNative providers are
effectively singletons, and should be treated as such.
For example. If you create a LocalNative connection using
C:\foo\webconfig.ini and then create another LocalNative connection using
C:\bar\webconfig.ini, the second connection will still be initialized with
the settings from C:\foo\webconfig.ini, because the respective
MgdPlatform.Initialize and MapGuideApi.MgInitializeWebTier methods that
these providers call into are only meant to be called once.
This has the following implications:
* You can't actually create multiple unique Local or LocalNative
connections in the same application session. In the case of Maestro, after
creating the first Local or LocalNative connection, you will actually have
to restart Maestro in order to be able to create a connection with a
different ini file.
* The MaestroAPI needs a way to programmatically check for this
* The Maestro Login dialog needs to guard against this. Basically once a
Local/LocalNative connection has been created, do not show the connection
UI. Instead the respective radio button should say "Connect to previous
<Local|TCP/IP> session" or something to that effect.
For the general use-cases (a normal desktop/web application), this would
rarely be a problem as the application is unlikely to be creating multiple
connections to different providers. But Maestro (with its multi-connection
support) exposes this problem wide open and needs to be gracefully
handled.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2151>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
