[Mapguide-trac] [mapguide-trac] #2154: Maestro on Mono: toolbar actions are not performed on the selected tab
MapGuide Open Source trac_mapguide at osgeo.org
Wed Oct 17 04:11:55 PDT 2012
   Reporter:  gabrimonfa  |       Owner:  jng
       Type:  defect      |      Status:  new
   Priority:  low         |   Milestone:
  Component:  Maestro     |     Version:
   Severity:  trivial     |    Keywords:
External_id:              |
 Maestro compiled from git updated on 2012-10-17
 Mono compiled from git updated on early October 2012 and updated on
 2012-10-17
 Ubuntu 12.04 64bit
 Sometimes toolbar actions are not performed on the selected tab element.
 How to reproduce:
   1. Open Maestro
   2. Open a MapDefinition, map1
   3. Open another MapDefinition, map2
   4. (the tab with map2 is selected) Choose an element from the toolbar
 (Preview, Edit as XML, Profile, Validate, Save)
   5. The action is applied to map1 while should be applied to map2
 Notes:
   - The bug probably also applies to shortcuts, Ctrl-s failed to save the
 selected unsaved map (but there are outbound requests, so probably another
 item - the one on the first tab? - is saved).
   - The bug applies also to other definitions, not only to maps
   - The bug only afflicts Mono version. I'm not able to reproduce the bug
 with the same binary on Windows
   - there's no mono warning or debug on the console
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2154>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
