[Mapguide-trac] [mapguide-trac] #2159: Layer properties visible in viewer, edit Display name has sometimes no effect.
MapGuide Open Source trac_mapguide at osgeo.org
Thu Oct 25 06:51:52 PDT 2012
effect.
   Reporter:  poulet1212  |       Owner:  jng
       Type:  defect      |      Status:  new
   Priority:  low         |   Milestone:  Maestro-4.0-maintenance
  Component:  Maestro     |     Version:  2.1.0
   Severity:  trivial     |    Keywords:
External_id:              |
 On Maestro 5.0.0.7047, when we setup a display name for a layer property,
 it sometimes does not change.
 I've noticed that these layer properties are unsynced between the XML
 editor and the GUI. For example editing a display name in the XML editor
 does not result in a modification on the GUI.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2159>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
