[Mapguide-trac] [mapguide-trac] #2160: Basic Layout editor available command selection goes wild
trac_mapguide at osgeo.org
Thu Oct 25 07:00:10 PDT 2012
Reporter: poulet1212 | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-4.0-maintenance
Component: Maestro | Version: 2.1.0
Severity: trivial | Keywords:
External_id: |
In the basic layout editor, under Menus and Toolbars, there is the little
button like |<<| to add a selected command to an actual menu. This button
toggles disabled/enabled in a quite "underteministic" way :-) after
clicking different commands in the right panel I can land on a command
with this button both enabled once or disabled next time.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2160>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
