[Mapguide-trac] [mapguide-trac] #2165: MgFeatureService::UpdateFeatures does not roll back transaction on exceptions when useTransaction = true
trac_mapguide at osgeo.org
Wed Oct 31 20:56:18 PDT 2012
Reporter: jng | Owner:
Type: defect | Status: new
Priority: high | Milestone:
Component: Feature Service | Version: 2.4.0
Severity: blocker | Keywords:
External_id: |
If you do a call to MgFeatureService::UpdateFeatures with useTransaction =
true, the transaction that gets created is not actually rolled back in the
event of an exception
The problem is in this line in
[http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Server/src/Services/Feature/ServerUpdateFeatures.cpp#L138
ServerUpdateFeatures.cpp]
MG_FEATURE_SERVICE_CHECK_CONNECTION_CATCH_AND_THROW(resource,
L"MgServerUpdateFeatures.UpdateFeatures")
if (transaction != NULL && !commited)
transaction->Rollback();
MG_FEATURE_SERVICE_THROW()
We should not be using MG_FEATURE_SERVICE_CHECK_CONNECTION_CATCH_AND_THROW
as any caught exceptions are immediately rethrown after its exception
processing has occurred. Because of this, the transaction rollback code
afterwards is never reached.
The fix is to replace that macro with
MG_FEATURE_SERVICE_CHECK_CONNECTION_CATCH, allowing the rollback code to
be executed. There is already a MG_FEATURE_SERVICE_THROW() macro defined
after the rollback code, so such caught exceptions will get re-thrown
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2165>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
