[Mapguide-trac] [mapguide-trac] #2112: maestro crash on linux viewing a weblayout in normal mode
MapGuide Open Source trac_mapguide at osgeo.org
Tue Sep 11 05:59:22 PDT 2012
   Reporter:  gabrimonfa  |       Owner:  jng
       Type:  defect      |      Status:  new
   Priority:  low         |   Milestone:
  Component:  Maestro     |     Version:
   Severity:  trivial     |    Keywords:
External_id:              |
 Maestro SVN update around the first days of September 2012
 Maestro 2.10.8 on Linux ubuntu
 System.InvalidCastException: Cannot cast from source type to destination
 type.
   at
 System.Reflection.MonoProperty.GetterAdapterFrame[BasicCommandType,BasicCommandActionType]
 (System.Reflection.Getter`2 getter, System.Object obj) [0x00000] in
 <filename unknown>:0
   at System.Reflection.MonoProperty.GetValue (System.Object obj,
 System.Object[] index) [0x00000] in <filename unknown>:0
   at System.ComponentModel.ReflectionPropertyDescriptor.GetValue
 (System.Object component) [0x00000] in <filename unknown>:0
   at System.Windows.Forms.DataGridViewCell.GetValue (Int32 rowIndex)
   at System.Windows.Forms.DataGridViewCell.get_Value () [0x00000] in
   at System.Windows.Forms.DataGridViewRow.PaintCells
 (System.Drawing.Graphics graphics, Rectangle clipBounds, Rectangle
 rowBounds, Int32 rowIndex, DataGridViewElementStates rowState, Boolean
 isFirstDisplayedRow, Boolean isLastVisibleRow, DataGridViewPaintParts
 paintParts) [0x00000] in <filename unknown>:0
   at System.Windows.Forms.DataGridViewRow.Paint (System.Drawing.Graphics
 graphics, Rectangle clipBounds, Rectangle rowBounds, Int32 rowIndex,
 DataGridViewElementStates rowState, Boolean isFirstDisplayedRow, Boolean
 isLastVisibleRow) [0x00000] in <filename unknown>:0
   at System.Windows.Forms.DataGridView.OnPaint
 (System.Windows.Forms.PaintEventArgs e) [0x00000] in <filename unknown>:0
   at System.Windows.Forms.Control.WmPaint (System.Windows.Forms.Message&
 m) [0x00000] in <filename unknown>:0
   at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message&
   at System.Windows.Forms.DataGridView.WndProc
 (System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
   at System.Windows.Forms.Control+ControlWindowTarget.OnMessage
   at System.Windows.Forms.Control+ControlNativeWindow.WndProc
   at System.Windows.Forms.NativeWindow.WndProc (IntPtr hWnd, Msg msg,
 IntPtr wParam, IntPtr lParam) [0x00000] in <filename unknown>:0
 Look like another mono problem
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2112>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
