[Mapguide-trac] [mapguide-trac] #2113: Fill in a fake password in the UI when opening a Feature Source with secured credentials
trac_mapguide at osgeo.org
Tue Sep 11 07:48:00 PDT 2012
secured credentials
Reporter: jng | Owner: jng
Type: enhancement | Status: new
Priority: low | Milestone: Maestro-4.0-maintenance
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
When opening a Feature Source with secured credentials, the password field
in the UI is blank. This is by-design as a populated password field means
that the Feature Source XML content contains the password in plaintext
which is a bad thing.
To remedy this from a usability perspective, the password field should be
filled in with a fake password. This won't actually modify the underlying
password as the writing of the password field to the MG_USER_CREDENTIALS
resource data item only happens when the user saves/tests the Feature
Source
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2113>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
