[Mapguide-trac] [mapguide-trac] #2114: Integrated API documentation
MapGuide Open Source trac_mapguide at osgeo.org
Tue Sep 11 22:10:45 PDT 2012
   Reporter:  jng            |       Owner:  jng
       Type:  enhancement    |      Status:  new
   Priority:  medium         |   Milestone:
  Component:  Documentation  |     Version:
   Severity:  major          |    Keywords:
External_id:                 |
 Doxygen supports XML output, allowing the MapGuide API documentation to be
 outputted into a logical, machine-processable XML form.
 There is a .net object-oriented library for working with doxygen comments
 in this form (http://code.google.com/p/doxygen-net/)
 With this, it should be possible to build a simple utility that can
 transform the doxygen XML output into javadoc or .net documentation XML,
 allowing for inline API documentation in your respective Java/.net IDE
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2114>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
