[Mapguide-trac] [mapguide-trac] #2115: Layer group can be moved into it's own sub group
MapGuide Open Source trac_mapguide at osgeo.org
Wed Sep 12 06:34:21 PDT 2012
   Reporter:  hm       |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-4.0-maintenance
  Component:  Maestro  |     Version:
   Severity:  minor    |    Keywords:
External_id:           |
 When modifying a Map in Maestro 4.0.2 if you by accident (or deliberately)
 drag a group into a subgroup beneath itself, the group and everything
 within it will disappear. If you open the map resource with the XML
 editor, the groups and their contents is still there, but for obvious
 reasons they are not listed any more.
 There should be some kind of check that a group cannot be moved into
 another group if the group being moved is in the
 parent/ancestor/hierarchy.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2115>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
