[Mapguide-trac] [mapguide-trac] #2125: Renaming groupname in MapDefinition is not reflected by childgroups
MapGuide Open Source trac_mapguide at osgeo.org
Tue Sep 18 00:49:49 PDT 2012
   Reporter:  gBecker   |       Owner:  jng
       Type:  defect    |      Status:  new
   Priority:  high      |   Milestone:  Maestro-5.0
  Component:  Maestro   |     Version:  2.4.0
   Severity:  critical  |    Keywords:
External_id:            |
 When you have the following structure in MapDefinition
 FolderA[[BR]]
 |_ Folder1[[BR]]
 |_ Folder2[[BR]]
 and you want to rename FolderA to FolderB (the name not just the
 LegendLabel) then the two descentend Folders disappear because their
 groupname node in xml doesn't reflect the changes of the parent.
 FolderB[[BR]]
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2125>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
