[Mapguide-trac] [mapguide-trac] #743: AGG Renderer does not properly handle transparency for non-PNG image formats
trac_mapguide at osgeo.org
Fri Sep 21 07:48:02 PDT 2012
formats
Reporter: gingerbbm | Owner:
Type: defect | Status: new
Priority: medium | Milestone: 2.4
Component: Rendering Service | Version: 2.2.0
Severity: major | Keywords:
External_id: |
Comment(by bscott):
I just worked around this problem.
the problem is not only related to the transparency but the image quality
in a whole.
GD does handle png8 very well ( neither png24 with transparency :) )
I have took some piece of code from Mapserver to fix the problem.
For my point of view the png8 output is very great. With Sheboygan i dont
see any difference between png24 and png8 except for the size of the image
( 3 to 4 time smaller)
Fix is done on MgDev/Common/Renderers/AGGImageIO.cpp
plus a new file mapquantization.cpp ( from mapserver )
Give it a try, i worth the effort
Just switch PNG to PNG8 in the ajaxmappane.templ
And therefore there is no reason to keep the selection image in PNG it
always should be PNG8
Patch is attached: high_quality_png8.patch
Bruno Scott
Geomap
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/743#comment:15>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
