[Mapguide-trac] [mapguide-trac] #2263: BUFFER tool : Error if the layer is based on a layer of a postgis table with two geometrical columns
MapGuide Open Source trac_mapguide at osgeo.org
Wed Apr 17 02:51:10 PDT 2013
   Reporter:  croux        |       Owner:
       Type:  defect       |      Status:  new
   Priority:  low          |   Milestone:
  Component:  AJAX Viewer  |     Version:  2.1.0
   Severity:  trivial      |    Keywords:  buffer
External_id:               |
 With a layer based on a postgis table with several geometrical columns, I
 have the following message when I use the buffer tool :
 "The specified object was not found"
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2263>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
