[Mapguide-trac] [mapguide-trac] #2324: Installer update for VS 2012
trac_mapguide at osgeo.org
Fri Aug 2 05:51:38 PDT 2013
Reporter: jng | Owner: jng
Type: task | Status: new
Priority: high | Milestone: 2.6
Component: Installer | Version:
Severity: major | Keywords:
External_id: |
Old description:
> * Include VS2012 vcredist installers
> * Update InstallerPreReq_VS2010.sln to VS2012. Keep the wix sln at
> VS2010 format as we can still build this through VS2012 via command-line
> * Remove Windows XP/2003 support (VC++ 2012 drops XP support and we're
> not building with XP re-targeting)
> * Remove iis_actions project as IIS7 is the minimum version as a
> result of dropping XP/2003 support
> * Remove IIS6 related sections from wix installer
> * There are two redundant sets of mapagent binaries. Only one is being
> used depending on whether it is the Apache/IIS configuration. We should
> tweak the configurations so that the same set of mapagent binaries are
> used, shaving off some installer space.
New description:
* Update InstallerPreReq_VS2010.sln to VS2012. Keep the wix sln at VS2010
* Update the FastCGI notice screen. Dropping XP/2003 means no external
download is required.
Comment(by jng):
Good call
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2324#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
