[Mapguide-trac] [mapguide-trac] #2333: Selection type is missing from the Maestro5 API enum OSGeo.MapGuide.MaestroAPI.ResourceType
    trac_mapguide at osgeo.org
    Mon Aug  5 05:46:23 PDT 2013
   Reporter:  hm       |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-5.0-maintenance
  Component:  Maestro  |     Version:
   Severity:  minor    |    Keywords:
External_id:           |
 Hi, I notised that the Selection type is missing from the Maestro5 API
 enum OSGeo.MapGuide.MaestroAPI.ResourceTypes?
 It wasn't present in Maestro4 API either, but with Maestro5 it fails when
 running this command:
 con.ResourceService.CopyResource("Session:abcxyz//MyMap.Selection",
 "Session:abcxyz//MyMapCopy.Selection", true);
 Internally the API is converting the extension string "Selection" to an
 enum, but fails becasue it does not exist.
 Adding Selection to the enum in OSGeo.MapGuide.MaestroAPI\Enums.cs fixes
 the problem.
 I guess the new API runs some code different than the old API since it now
 causes problems, and not before.
 Best regards
   Hans Milling...
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2333>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
