[Mapguide-trac] [mapguide-trac] #2174: GDAL - MapImage with stripes
trac_mapguide at osgeo.org
Tue Aug 6 08:11:47 PDT 2013
Reporter: zspitzer | Owner:
Type: defect | Status: new
Priority: high | Milestone: 2.6
Component: Rendering Service | Version: 2.4.0
Severity: major | Keywords:
External_id: |
Comment(by jng):
Here's my observations thus far.
The striped effect happens when your MaxRasterImageHeight and
MaxRasterImageWidth are greater than the size of the image you are
requesting.
This conclusion was made through 5 tests with various serverconfig.ini
values using your sample request.
Test case #1:
MaxRasterImageHeight = 2048 (default)
MaxRasterImageWidth = 2048 (default)
No stripes
Test case #2:
MaxRasterImageHeight = 3072 (default)
MaxRasterImageWidth = 3072 (default)
No stripes
Test case #3:
MaxRasterImageHeight = 4096 (default)
MaxRasterImageWidth = 4096 (default)
Striped effect occurs
Test case #4:
MaxRasterImageHeight = 4000 (default)
MaxRasterImageWidth = 4000 (default)
No striped effect
Test case #5:
MaxRasterImageHeight = 4001 (default)
MaxRasterImageWidth = 4001 (default)
Striped effect occurs.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2174#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
