[Mapguide-trac] [mapguide-trac] #2336: New map resources is always created as version 2.4.0
MapGuide Open Source trac_mapguide at osgeo.org
Wed Aug 7 00:28:15 PDT 2013
   Reporter:  hm       |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-5.0-maintenance
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 Using Maestro 5.0.0.7698 when I create a new map definition, even though I
 select version 1.0.0, the map is always created as resource version 2.4.0.
 WOrk arround is to edit the XML manually to revert it back to 1.0.0. But
 the problem is if you create some maps and export these to import on MGOS
 2.2 this is not possible without manually editing the XML files first.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2336>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
