[Mapguide-trac] [mapguide-trac] #2389: Watermark: Maestro does not read Unit
trac_mapguide at osgeo.org
Mon Dec 16 02:58:05 PST 2013
Reporter: znarf1965 | Owner:
Type: defect | Status: new
Priority: low | Milestone:
Component: General | Version: 2.5.0
Severity: minor | Keywords: watermark
External_id: |
Maestro does not read Unit when opening a watermark definition. If, for
example, you set "Pixels", save and re-open Watermark, Maestro will
display his default "Inches". But if you open as XML you can see right
"Unit" type you saved. This is a problem related to how Maestro read an
existing definition.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2389>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
