[Mapguide-trac] [mapguide-trac] #2393: Make textsymbol more configurable
MapGuide Open Source trac_mapguide at osgeo.org
Mon Dec 23 07:05:27 PST 2013
   Reporter:  gabrimonfa   |       Owner:
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  General      |     Version:  2.5.0
   Severity:  trivial      |    Keywords:
External_id:               |
 v. 2.5.2.7949
 textsymbol.templ in mapguide/webserverextensions/www/viewerfiles has many
 options that are not configurable, as
 <Unit>Points</Unit>
 <SizeContext>DeviceUnits</SizeContext>
 <Rotation>0</Rotation>
 <BackgroundColor>FF000000</BackgroundColor>
 <BackgroundStyle>Transparent</BackgroundStyle>
 <HorizontalAlignment>Center</HorizontalAlignment>
 <VerticalAlignment>Baseline</VerticalAlignment>
 I suggest to transform them in %s and to modify the functions that use the
 template in order to accept more parameters (with default values equals to
 those actually written in the template, in order to let older code run
 without modifications).
 F.i. in layerdefinitionfactory.php
 static function CreateTextSymbol($text, $fontHeight, $foregroundColor)
 should become something like
 $foregroundColor,
 $unit='Points',
 $sizeContext='DeviceUnits',
 $rotation=0,
 $font='Arial',
 $backgroundColor='FF000000',
 $backgroundStyle='Transparent',
 $horizontalAlignment='Center',
 $verticalAlignment='Baseline')
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2393>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
