[Mapguide-trac] [mapguide-trac] #2207: MgCooker command line ignores scale index
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jan 18 01:33:22 PST 2013
   Reporter:  hm       |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-4.0-maintenance
  Component:  Maestro  |     Version:
   Severity:  minor    |    Keywords:
External_id:           |
 When using MgCooker and choosing only to generate tiles for the first 5
 zoom levels, this works fine, but if I save as script and run the bat
 file, the --scaleindex parameter seems to have no effect.
 MgCooker.jpg    - The setup in MgCooker.
 CommandLine.png - Output when BAT file is run.
 The BAT file has this line:
 MgCooker.exe batch
 --mapdefinitions="Library://Kort/Baggrundskort.MapDefinition"
 --basegroups="Baggrundskort" --scaleindex=10,11,12,13,14
 --mapagent="http://46.137.164.90/mapguide22/" --username="Administrator"
 --password="admin"
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2207>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
