[Mapguide-trac] [mapguide-trac] #2209: WMS with EPSG 21781 draw wrong
trac_mapguide at osgeo.org
Sat Jan 26 07:53:39 PST 2013
Reporter: znarf1965 | Owner:
Type: defect | Status: new
Priority: high | Milestone:
Component: WMS Interface | Version: 2.4.0
Severity: critical | Keywords:
External_id: |
There is an issue on rendering WMS on EPSG 21781.
In general when using standard EPSG 4326, MGOS/AIMS they both draw well
(but slow).
But when using EPSG 21781, MGOS/AIMS they both draw very bad and sometimes
totally wrong.
I use the following WMS for test (but I get exactly the sme result for all
swiss WMS)
http://webgis.uster.ch/wms/admin/administrative_grenzen?version=1.3.0
I prepared a simple example that shows the problem.
- Map Library://Test/Default.epsg21781.MapDefinition draw polygons in
grey.
This map has original coordinate generated by Map3D
- Map Library://Test/Default.epsg21781.MapDefinition draw polygons in grey
again.
This map has EPSG 21781 with WKT got from "translate" tag in
OgcWmsService.config.owt
- Map Library://Test/Default.epsg4326.MapDefinition draw polygons with
right colors.
The problem is serious because there is no possibilities to read WMS with
this coordinate systems and this make AIMS/MGOS not usable in many cases.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2209>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
