[Mapguide-trac] [mapguide-trac] #2230: Describe schema from SQL Server failed when using user-defined functions in calculation property
MapGuide Open Source trac_mapguide at osgeo.org
Sun Mar 10 23:48:31 PDT 2013
   Reporter:  zhanga           |       Owner:  zhanga
       Type:  defect           |      Status:  new
   Priority:  low              |   Milestone:  2.5
  Component:  Feature Service  |     Version:  2.4.0
   Severity:  major            |    Keywords:
External_id:  1493845          |
 If using user-defined functions when creating a calclation property in a
 SQL Server feature source, the describe schema command always failed. The
 error message is: Item "xxx" not found in collection.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2230>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
