[Mapguide-trac] [mapguide-trac] #2234: Maestro: fail to choose coordinate system by EPSG
trac_mapguide at osgeo.org
Thu Mar 21 08:49:51 PDT 2013
Reporter: gabrimonfa | Owner: jng
Type: defect | Status: new
Priority: low | Milestone:
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
Maestro trunk updated on 2013-03-21
In Select Coordinate System if I choose "Type EPSG code" and insert 3003
(Monte Mario Rome Italy1) and press "Validate" it does not complete the
other CS info.
In the Outbound messages I can see a GET message with contains the correct
CS in the parameters (f.i. CSWKT contains MonteMario_1.Italy)
The GET message receives a 200 from the server.
The previous CS of the map was arbitrary (LOCAL_CS).
If I choose the CS from "Select by list" all works correctly
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2234>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
