[Mapguide-trac] [mapguide-trac] #2235: Maestro: Select Coordinate Systems window on open send wrong messages to the server
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 21 08:53:56 PDT 2013
the server
   Reporter:  gabrimonfa  |       Owner:  jng
       Type:  defect      |      Status:  new
   Priority:  low         |   Milestone:
  Component:  Maestro     |     Version:
   Severity:  trivial     |    Keywords:
External_id:              |
 Maestro trunk SVN updated on 2013-03-21
 Opening Select Coordinate Systems window in a map with LOCAL_CS Coordinate
 Systems logs the following lines in the OutBound Requests:
 [21 mar 2013 04.52.36]: 500 Internal Server Error GET
 /mapguide/mapagent/mapagent.fcgi?OPERATION=CS.ENUMERATECOORDINATESYSTEMS&VERSION=1.0.0&SESSION=f297d9c0
 -923c-
 11e2-8000-5254009289ef_en_MTI3LjAuMC4x0AFC0AFB0AFA&FORMAT=text%2fxml&CLIENTAGENT=MapGuide+Maestro+v5.0.0.6640&CSCATEGORY=Argentina
 -923c-
 No error message is logged server side
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2235>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
