[Mapguide-trac] [mapguide-trac] #2243: Problems with Widgets in Fusion layouts
trac_mapguide at osgeo.org
Mon Mar 25 23:34:00 PDT 2013
Reporter: juanita | Owner:
Type: defect | Status: closed
Priority: high | Milestone: 2.5
Component: Fusion Templates | Version: 2.4.0
Severity: minor | Resolution: fixed
Keywords: Scalebar, CenterSelection, CTRLClick | External_id:
Changes (by jng):
* status: new => closed
* resolution: => fixed
Comment:
* CenterSelection: It's an issue with the widget code. See
[http://trac.osgeo.org/fusion/ticket/559 Fusion ticket 559]
* Scalebar: This is not a dockable widget, such widgets cannot be housed
within a toolbar or menu. Maestro has been updated to better distinguish
between dockable and non-dockable widgets and will prevent you from doing
such illegal actions. See #2236
* CTRLClick: This widget does not exist anymore. However Maestro thinks
it still exists because the widgetinfo xml file is still there. See
[http://trac.osgeo.org/fusion/ticket/558 Fusion ticket 558]
Please follow the individual tickets I've linked to know when they'll be
resolved. They *will* be resolved before the 2.5 final release of
MapGuide.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2243#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
