[Mapguide-trac] [mapguide-trac] #2249: Do not dispatch GETDYNAMICOVERLAYIMAGE requests if any display parameter values are <= 0
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 28 08:02:49 PDT 2013
values are <= 0
   Reporter:  jng          |       Owner:
       Type:  defect       |      Status:  new
   Priority:  low          |   Milestone:
  Component:  AJAX Viewer  |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 The cause of those "value cannot be less than zero" exceptions in
 MgRenderingService::RenderDynamicOverlay is most likely caused by the AJAX
 Viewer firing off GETDYNAMICOVERLAYIMAGE requests willy-nilly without any
 sort of client-side verification.
 The viewer should be doing this verification. Do not send a
 GETDYNAMICOVERLAYIMAGE request if any of the parameters are <= 0:
  * width
  * height
  * dpi
  * scale
  * metersPerUnit
 This should cut down on the incidences of such exceptions being logged
 server-side
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2249>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
