[Mapguide-trac] [mapguide-trac] #2250: Broken IIS6 / IIS5.1 setup
MapGuide Open Source trac_mapguide at osgeo.org
Sat Mar 30 02:23:56 PDT 2013
   Reporter:  jng        |       Owner:  jng
       Type:  defect     |      Status:  new
   Priority:  high       |   Milestone:  2.5
  Component:  Installer  |     Version:
   Severity:  blocker    |    Keywords:
External_id:             |
Description changed by jng:
Old description:
> IIS6 and IIS5.1 is currently broken.
> The reason for the breakage is that the OSGeo.MapGuide.*.xml
> documentation files are being copied into the Php directory, offsetting
> the expected position of the php-cgi.exe executable.
> The build scripts need to exclude these files. Restoring php-cgi.exe back
> to its expected position.
New description:
 The reason for the breakage is that the OSGeo.MapGuide.*.xml documentation
 files are being copied into the Php directory, offsetting the expected
 position of the php-cgi.exe executable, thus the wrong file is being
 registered as the PHP FastCGI executable.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2250#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
