[Mapguide-trac] [mapguide-trac] #2272: Unable to load the FDO Provider library:PostgreSQLProvider.dll
trac_mapguide at osgeo.org
Sat May 18 21:06:21 PDT 2013
Reporter: hc27080401 | Owner: jng
Type: defect | Status: new
Priority: high | Milestone: Maestro-5.0
Component: Maestro | Version:
Severity: critical | Keywords:
External_id: |
Hi:
When I want to use PostgreSQLProvider as the feature source,the problem
encountered.the following is the details:
System.Exception: The remote server returned an error: (559)
MgFdoException.: An exception occurred in FDO component.Unable to load the
FDO Provider library '.\PostgreSQLProvider.dll': 找不到指定的模块。 (Cause: , Root
Cause: Unable to load the FDO Provider library '.\PostgreSQLProvider.dll':
找不到指定的模块。 )
- MgFeatureServiceHandler.ProcessOperation() line 83 file
c:\mg-2.5-x86\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpGetCapabilities.Execute() line 124 file
c:\mg-2.5-x86\mgdev\server\src\services\feature\OpGetCapabilities.cpp
---> System.Net.WebException: The remote server returned an error: (559)
MgFdoException.
at System.Net.HttpWebRequest.GetResponse()
at OSGeo.MapGuide.MaestroAPI.HttpServerConnection.OpenRead(String req)
in c:\Program Files (x86)\Jenkins\jobs\Maestro
4.0.x\workspace\OSGeo.MapGuide.MaestroAPI.Http\HttpServerConnection.cs:line
1221
--- End of inner exception stack trace ---
1237
at
OSGeo.MapGuide.MaestroAPI.HttpServerConnection.GetProviderCapabilities(String
provider) in c:\Program Files (x86)\Jenkins\jobs\Maestro
1662
at Maestro.Base.Editor.FsEditorOptionPanel.Bind(IEditorService service)
4.0.x\workspace\Maestro.Base\Editor\FsEditorOptionPanel.cs:line 60
at Maestro.Base.Editor.FeatureSourceEditor.Bind(IEditorService service)
4.0.x\workspace\Maestro.Base\Editor\FeatureSourceEditor.cs:line 63
at
Maestro.Base.Editor.EditorContentBase.set_EditorService(IEditorService
value) in c:\Program Files (x86)\Jenkins\jobs\Maestro
4.0.x\workspace\Maestro.Base\Editor\EditorContentBase.cs:line 81
at Maestro.Base.Services.OpenResourceManager.Open(IResource res,
IServerConnection conn, Boolean useXmlEditor, ISiteExplorer siteExp) in
4.0.x\workspace\Maestro.Base\Services\OpenResourceManager.cs:line 164
at Maestro.Base.Services.OpenResourceManager.Open(String resourceId,
4.0.x\workspace\Maestro.Base\Services\OpenResourceManager.cs:line 220
my developement enviroment:
operation system:win7 x64
Maestro:version 4.0.4,the latest version is the same problem
mapguide open source :version 2.5.0.7449 x86
postgresql version:9.2.4.1 x64
please help me!
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2272>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
