[Mapguide-trac] [mapguide-trac] #2280: Parameterize Apache/PHP include/linker paths
trac_mapguide at osgeo.org
Wed May 29 19:11:25 PDT 2013
Reporter: jng | Owner:
Type: enhancement | Status: new
Priority: low | Milestone: 2.6
Component: Build System | Version:
Severity: trivial | Keywords:
External_id: |
The web tier currently uses hard-coded Apache/PHP linker paths in its
vcxproj and makefiles
We should parameterize these paths using environment variables.
This way, should we choose to not build MapGuide against our bundled
Apache/PHP all we need to do is set the appropriate environment variables
to our desired Apache/PHP paths.
This will improve builds on Linux, where it is more preferable to tap into
the system installed Apache/PHP rather than building our own.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2280>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
