[Mapguide-trac] [mapguide-trac] #2281: Use PropertyGrid for Layer/Group properties in Map Definition Editor
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 29 21:46:53 PDT 2013
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-5.1
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 We should consider using the WinForms PropertyGrid for editing Layer/Group
 properties in the Map Definition Editor.
 The reason being the PropertyGrid component supports editing properties of
 *multiple* objects at once. For a Map Definition with lots of layers
 (100+) being able to batch edit a series of layers (eg.  Turn on/off
 selectability for a series of layers) is an incredibly time-saving feature
 to have.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2281>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
