[Mapguide-trac] [mapguide-trac] #2282: Generate theme throws NRE if no Feature Class assigned
trac_mapguide at osgeo.org
Thu May 30 21:44:24 PDT 2013
Reporter: jng | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-5.0
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
The Generate theme function in the Layer Definition will throw a NRE if no
feature class has been assigned. The function should check for this state
and abort if this is the case.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2282>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
