[Mapguide-trac] [mapguide-trac] #2375: Path scales not applied to geometry when ResizeControl set to 'AdjustToResizeBox'
trac_mapguide at osgeo.org
Sun Nov 3 12:41:23 PST 2013
'AdjustToResizeBox'
Reporter: waltweltonlair | Owner: waltweltonlair
Type: defect | Status: new
Priority: low | Milestone: 2.6
Component: Rendering Service | Version: 2.5.0
Severity: minor | Keywords:
External_id: |
I ran into this yesterday while experimenting with resize box behavior.
In a symbol definition I had a Path graphic element with !ResizeControl
set to '!AdjustToResizeBox', and noticed that the path's ScaleX and ScaleY
properties were being ignored. If I set !ResizeControl to '!ResizeNone'
(the default) then they once again took effect.
Path scaling was added as part of RFC 113. The need to update the
behavior for '!AdjustToResizeBox' was probably just overlooked.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2375>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
