[Mapguide-trac] [mapguide-trac] #2376: Chrome 29/30 Basic layout: legend pane at the beginning does not respect its height
MapGuide Open Source trac_mapguide at osgeo.org
Thu Nov 7 03:31:16 PST 2013
its height
   Reporter:  gabrimonfa  |       Owner:
       Type:  defect      |      Status:  new
   Priority:  low         |   Milestone:
  Component:  General     |     Version:  2.5.0
   Severity:  trivial     |    Keywords:
External_id:              |
 In Google Chrome 29,30 using basic layout, legend pane at the beginning
 starts very small, without respecting its height.
 See the attached image in which is clearly visible the scrollbar.
 All works correctly in Firefox 25 and IE8
 The same happens also if property pane is disabled (as in the case of the
 attached image).
 The proposed patch seems to solve the problem.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2376>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
