[Mapguide-trac] [mapguide-trac] #2370: Can't log onto Maestro 4.0.0
trac_mapguide at osgeo.org
Thu Oct 17 23:44:11 PDT 2013
Reporter: educker | Owner: jng
Type: defect | Status: new
Priority: medium | Milestone:
Component: Maestro | Version: 2.2.0
Severity: minor | Keywords: 559 MgConnectionFailedException
External_id: |
Hi Guys,
I've installed Maestro onto Win7 64bit along with mapguide 2.2 It's
running on apache 2.2.21 and I can't log on to the port it's set up for. I
get this error in windows
Failed to log on because: Failed to connect, please check network
connection and login information. Extended error info:
The remote server returned an error: (559) MgConnectionFailedException.
Checking the error.log for apache I'm seeing this set of messages after
restarting apache then trying to log into maestro
[Fri Oct 18 15:01:51 2013] [notice] Child 2564: Exit event signaled. Child
process is ending. [Fri Oct 18 15:01:51 2013] [notice] Apache/2.2.21
(Win64) configured -- resuming normal operations [Fri Oct 18 15:01:51
2013] [notice] Server built: Feb 2 2012 02:03:24 [Fri Oct 18 15:01:51
2013] [notice] Parent: Created child process 5068 [Fri Oct 18 15:01:51
2013] [notice] Disabled use of AcceptEx?() WinSock?2 API [Fri Oct 18
15:01:51 2013] [notice] Child 5068: Child process is running [Fri Oct 18
15:01:52 2013] [notice] Child 5068: Acquired the start mutex. [Fri Oct 18
15:01:52 2013] [notice] Child 5068: Starting 50 worker threads. [Fri Oct
18 15:01:52 2013] [notice] Child 2564: Released the start mutex [Fri Oct
18 15:01:52 2013] [notice] Child 2564: All worker threads have exited.
[Fri Oct 18 15:01:52 2013] [notice] Child 2564: Child process is exiting
[Fri Oct 18 15:01:53 2013] [notice] Child 5068: Listening on port 8250. (
7 6 6 4 ) D e f a u l t D i r : " C : \ P r o g r a m D a t a \ A u t o d
e s k \ G e o s p a t i a l C o o r d i n a t e S y s t e m s " i s n o t
a d i r e c t o r y ! I n s t a l l t h e C o o r d i n a t e S y s t e m
l i b r a r y i n t o t h i s d i r e c t o r y o r s e t M E N T O R _ D
I C T I O N A R Y _ P A T H t o w h e r e t h e y a r e c u r r e n t l y
i n s t a l l e d .
( 7 6 6 4 ) M g C o o r d i n a t e S y s t e m I n i t i a l i z a t i o
n F a i l e d E x c e p t i o n c a u g h t i n C C o o r d i n a t e S y
s t e m C a t a l o g c o n s t r u c t o r - T h e c o o r d i n a t e s
y s t e m i n i t i a l i z a t i o n f a i l e d .
M g C o o r d i n a t e S y s t e m C a t a l o g . S e t D e f a u l t D
i c t i o n a r y D i r A n d F i l e N a m e s ( ) l i n e 6 0 4 f i l e
. . \ C o o r d i n a t e S y s t e m \ C o o r d S y s C a t a l o g . c
p p
M g C o o r d i n a t e S y s t e m C a t a l o g . G e t D e f a u l t D
i c t i o n a r y D i r ( ) l i n e 2 6 3 f i l e . . \ C o o r d i n a t
e S y s t e m \ C o o r d S y s C a t a l o g . c p p
[Fri Oct 18 15:07:00 2013] [error] [client 127.0.0.1] File does not exist:
C:/Program Files (x86)/OSGeo/MapGuide/Web/Apache2/htdocs/favicon.ico
Any ideas why it's not working correctly?
Thanks,
Edward
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2370>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
