[Mapguide-trac] [mapguide-trac] #2350: Remove/Detach BaseMapDefinition element if deleting last finite scale or group
trac_mapguide at osgeo.org
Mon Sep 2 21:54:30 PDT 2013
group
Reporter: jng | Owner: jng
Type: defect | Status: new
Priority: low | Milestone:
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
When deleting a finite scale or a base layer group from the Map Definition
editor, it should check if this results in an empty BaseMapDefinition
element. If so, then the editor should just remove the element itself,
thus avoiding a content model error when being saved.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2350>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
