[Mapguide-trac] [mapguide-trac] #2351: Maestro 5 - Package restore LoadProcedure paths
trac_mapguide at osgeo.org
Mon Sep 2 23:13:41 PDT 2013
Reporter: hm | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-5.1
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
Using Maestro 5, when I create a package that contains some load
procedures. If i set a restore path to something different, everything
seems to load fine on another server. But the Load Settings "Load
Resources Into Folder" and "Layer Definitions" paths in the load procedure
is still pointing to the old path. I am not sure if this is intended (by
design) or not?
I guess there could be cases where you do not want to change these paths,
but in my case I need it changed. One resolution could be in the Create
Package window to introduce a checkbox "Change Load procedure paths as
well" or something like that. When checked the paths of the load procedure
load settings (if in the path beeing backed up) will also be changed to
the new path.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2351>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
