[Mapguide-trac] [mapguide-trac] #2358: Parameterize Maestro API test runner test suite settings
trac_mapguide at osgeo.org
Fri Sep 6 06:35:21 PDT 2013
Reporter: jng | Owner: jng
Type: task | Status: new
Priority: low | Milestone: Maestro-5.1
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
Currently the Maestro API test runner's test suites are information that's
compiled into the executable. For greater flexibility, such information
should be able to be passed in from the command-line and such conditional
tests should be able to programmatically ignore any tests that cannot be
executed under the current environment conditions (eg. Ignore testing the
LocalNative tests if we don't have the official MapGuide API assemblies
with us)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2358>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
