[Mapguide-trac] [mapguide-trac] #2477: mgcooker tile calculations
trac_mapguide at osgeo.org
Mon Aug 4 07:32:58 PDT 2014
Reporter: gvtomm | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-6.0
Component: Maestro | Version: 2.5.0
Severity: trivial | Keywords:
External_id: |
The area covered by the tiles generated by mgcooker is higher than the
expected area, when both situations occurs:
- override bounds is set
- width/height of the specified area bounds is higher than tile
width/height in meters for a specific scale (for example the tile width at
scale XX is 1000 meters, and the width of bounds area is 1500 meters)
The correction I would propose is on then attached image.
gvtomm
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2477>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
