[Mapguide-trac] [mapguide-trac] #2470: WebTier-Crash: MgGeometry.intersection() not thread safe
MapGuide Open Source trac_mapguide at osgeo.org
Fri Aug 15 03:01:48 PDT 2014
   Reporter:  andymorf  |       Owner:
       Type:  defect    |      Status:  new
   Priority:  high      |   Milestone:
  Component:  Web API   |     Version:  2.5.0
   Severity:  critical  |    Keywords:
External_id:            |
Comment(by andymorf):
 I understand your suspicion - on the other hand I only see access
 violations/crashes within GEOS-classes and in my case the the arguments
 which  are sent are of type MgGeometry which are not constructed within
 java (origin is always MgFeatureReader).
 All the other MgJavaAPI-calls in my servlets (a lot of them) seem to work
 ok.
 After reading your RFC141 i must admit that I am using GEOS-3.3.x version
 but since already two years without any problem - problem arised when
 switching from vc10 to vc12.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2470#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
