[Mapguide-trac] [mapguide-trac] #2481: RenderMap with keepSelection = true only shows outlines of selections
trac_mapguide at osgeo.org
Wed Aug 20 06:58:16 PDT 2014
Reporter: jng | Owner: jng
Type: defect | Status: new
Priority: low | Milestone:
Component: Rendering Service | Version: 2.6.0
Severity: trivial | Keywords:
External_id: |
When RenderMap is called with keepSelection = true, the selected features
are only outlined and not filled.
This is due to r8065 (fixing #852), the fix there is incomplete. When
SetRenderMode() is called without an rgba value, it defaults to blue with
an alpha of 0, which means the fill will be fully transparent.
To restore previous behaviour, SetRenderMode() without an rgba should
default to blue with an alpha of '''255'''. This will trigger the backward
compatibility code path.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2481>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
