[Mapguide-trac] [mapguide-trac] #2400: MENTOR_DICTIONARY_PATH var env problem with MAP3D
trac_mapguide at osgeo.org
Mon Feb 3 04:58:57 PST 2014
Reporter: poulet1212 | Owner:
Type: defect | Status: new
Priority: low | Milestone:
Component: Installer | Version: 2.5.0
Severity: trivial | Keywords: MENTOR_DICTIONARY_PATH, map3d
External_id: |
Guys,
I'm running Autodesk Map 3D 2013 and after installing MGOS, I was unable
to see my maps because of coordinate system missing error.
The fact is that MGOS setup a MENTOR_DICTIONARY_PATH env. var. to
C:\Program Files\OSGeo\MapGuide\CS-Map\Dictionaries\
It seems that Autodesk Map 3D doesn't setup such an env. var. but will use
it if it has been set.
I resolved this issue by setting this variable to the folder that Autocad
currently uses:
C:\Documents and Settings\All Users\Application Data\Autodesk\Geospatial
Coordinate Systems 2013
Would be nice to have a mean to setup this variable correctly if there is
an existing Autocad Map installation.
-- You can see more details here from someone asking the Autodesk support.
http://forums.autodesk.com/t5/AutoCAD-Map-3D-General/Map-2012-Coordinate-
system-files-missing/m-p/3014858/highlight/true
If the link is no more valid i let uereby a pdf of it.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2400>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
