[Mapguide-trac] [mapguide-trac] #2397: Mapguide aborted if cannot find a session db it is trying to wipe
trac_mapguide at osgeo.org
Tue Jan 21 02:56:37 PST 2014
Reporter: gabrimonfa | Owner:
Type: defect | Status: new
Priority: low | Milestone:
Component: General | Version: 2.5.0
Severity: trivial | Keywords:
External_id: |
Due to an error I've removed some active session db and dbxml from a
living MapGuide server (2.5.2).
Mapguide then aborted logging
15d375d0-7c65-11e3-8000-5254006ae79a_en_MTI3LjAuMC4x0AFC0AFB0AFA.db:
unable to flush: No such file or directory
15d375d0-7c65-11e3-8000-5254006ae79a_en_MTI3LjAuMC4x0AFC0AFB0AFA.dbxml:
mgserver: DbEnvironment.cpp:239: virtual
MgDbEnvironment::~MgDbEnvironment(): Assertion `false' failed.
./mgserver.sh: line 8: 24225 Aborted ./mgserver run
The relevant code in 2.5 branch is
http://trac.osgeo.org/mapguide/browser/branches/2.5/MgDev/Server/src/Services/Resource/DbEnvironment.cpp
229 MgDbEnvironment::~MgDbEnvironment()
230 {
231 if (m_opened)
232 {
233 try
234 {
235 m_dbEnv.close(0);
236 }
237 catch (...)
238 {
239 assert(false);
240 }
241 }
242 }
While the problem is an error on my side, I would suggest to make MapGuide
more robust, logging the error and continuing instead of asserting and
aborting.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2397>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
