[Mapguide-trac] [mapguide-trac] #2407: Support individual theme generation by values in a "lookup" Class Definition
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 13 21:11:40 PDT 2014
Definition
   Reporter:  jng          |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  medium       |   Milestone:  Maestro-5.2
  Component:  Maestro      |     Version:
   Severity:  major        |    Keywords:
External_id:               |
 When generating a theme of individual values, the actual values are being
 sampled from the Class Definition the layer will render off of.
 If the property being themed on is a foreign key to some external lookup
 table, the theme that gets generated isn't very meaningful as any
 generated labels will be using the "ID" value instead of the
 "label/description" value that would normally be in the lookup table that
 the foreign key links to.
 In such a situation, it would be very useful to offer the user the ability
 to generate a theme based on values of the lookup table itself.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2407>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
