[Mapguide-trac] [mapguide-trac] #2419: Theming support for composite styles
trac_mapguide at osgeo.org
Sat Mar 29 10:41:27 PDT 2014
Reporter: jng | Owner: jng
Type: enhancement | Status: new
Priority: low | Milestone: Maestro-5.2
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
Add support for creating themes for composite styles.
Due to the increased complexity of composite styles, we theme as follows:
* For each color in theme ramp the first defined fill color in the
composite style. This could be:
* A FillColor property of a Path graphic
* A default value for a Fill Color parameter (if FillColor property is
a symbol parameter reference)
* The override value for a Fill Color parameter (if defined)
* Whichever one we find, we replace that color at that same spot in a
cloned copy with the current color in the theme ramp.
* Add this cloned copy to the composite style
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2419>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
