[Mapguide-trac] [mapguide-trac] #2422: Total is not calculated correctly if user changes the measure unit in Measure Distance
trac_mapguide at osgeo.org
Mon Mar 31 00:43:39 PDT 2014
Measure Distance
Reporter: christinebao | Owner: Christine Bao
Type: defect | Status: new
Priority: medium | Milestone:
Component: General | Version: 2.5.0
Severity: trivial | Keywords:
External_id: DE9930 |
Reported by Autodesk QA:
steps:
1. in Browser, open a basic web layout
2. view map in 1:100000 scale so that we can verify the calculation easily
later
3. click 'Measure' button, so there is a Measure Distance dialog in Task
pane
4. select Measure units as Kilometers
5. Draw a 1 cm long line on the map, so in Measure dialog, it displays
Segment: 1.00 (Kilometers), Total: 1.00 (Kilometers)
6. select Measure units as Meters
7. you will find : the segment: 1.00(Meters), Total: 1.00 (Meters)
8. continue to draw another 2 cm long line on the map
result: the segment: 2000.00(Meters), Total: 2001.00 (Meters)
expected: the segment: 2000.00(Meters), Total: 3000.00 (Meters)
regression:
no, it exists in Knight. but Jedi, it does't have such use case (as user
can't change the unit).
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2422>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
