[Mapguide-trac] [mapguide-trac] #2400: MENTOR_DICTIONARY_PATH var env problem with MAP3D
trac_mapguide at osgeo.org
Mon Mar 31 05:38:43 PDT 2014
Reporter: poulet1212 | Owner:
Type: defect | Status: closed
Priority: low | Milestone:
Component: Installer | Version: 2.5.0
Severity: trivial | Resolution: worksforme
Keywords: MENTOR_DICTIONARY_PATH, map3d | External_id:
Changes (by jng):
* status: new => closed
* resolution: => worksforme
Comment:
The installer doesn't set MENTOR_DICTIONARY_PATH anymore, nor does
MapGuide use it as a first point of contact (serverconfig.ini and
webconfig.ini take precedence).
This probably means what you have is some leftover from a previous
installation.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2400#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
